| best engine for me https://slantsix.org/forum/viewtopic.php?t=50686 |
| Author: | MOUSETRAP [ Tue Jan 01, 2013 9:05 am ] |
| Post subject: | best engine for me |
i am looking to build a long rod 225 with 833od 4:10 rear gears . this is a driver on premium pump gas with a few trips to drags grudge night or vintage days 1/4 mile .also a 75hp -100hp nitrous shot at the drags . is the cast crank year engines strong enough for this or is forged better for me? would the cast crank be lighter and rev quicker to help with gaps in tranny ratio's ? thanks smitty |
| Author: | MOUSETRAP [ Fri Jan 04, 2013 10:18 pm ] |
Cast crank with 100hp nitrous ? I don't have a engine yet asking to know if I should find forged crank or cast crank engine thanks |
| Author: | DusterIdiot [ Fri Jan 04, 2013 10:25 pm ] |
| Post subject: | Yes... |
Quote: would the cast crank be lighter and rev quicker to help with gaps in tranny ratio's ?
Can't answer on the NO2, but the cast crank will build the revs back quicker than the heavier forged crank, but the wide ratio still will not allow you to use anything above 3rd(I thought that a 4.56 would do the trick in helping the engine rebuild the RPM, but a shift to OD is usually a few feet from the finish line and isn't worth the shift).-D.idiot |
| Author: | slantzilla [ Sat Jan 05, 2013 3:22 am ] |
The first nitrous Slant door car into the 10's used a cast crank motor with well over a 100 shot on it. Cast crank will mean custom rods. 198 rods won't work. |
| Author: | Joshie225 [ Sat Jan 05, 2013 9:54 am ] |
I've run an A833OD with 4.10s and while it works passably well on the street the ratios are much too far apart for good performance. The difference really shows up on the track (I was road racing) and a change to the 'regular' A833 made the car faster and much more fun. If I had to run such a combination on the street again I would save my money for a 5-speed or a Gear Vendors overdrive. |
| Author: | Rug_Trucker [ Sat Jan 05, 2013 10:24 am ] |
Quote: Cast crank will mean custom rods. 198 rods won't work. |
| Author: | Supercharged SL6 [ Sat Jan 05, 2013 4:17 pm ] |
Just buy a set of K1 rods |
| Author: | Dart270 [ Sun Jan 06, 2013 8:46 am ] |
Yes, you can machine 198 rods to fit the narrower crank, but K1 (or Molnar) has made the narrow 7" rods and they are nice. I have a set in my new cast crank motor. You should have no trouble at those power levels. Lou |
| Author: | MOUSETRAP [ Wed Jan 09, 2013 6:31 am ] |
What would be max rpm and stay dependable ?? cast or forged crank engine with k1 rods wisco pistons Flywheel not flex plate. Big valves big cam Asking about rotating lower end I will assume I need to match top end to feed or match to make it run right at max rpm thanks for all your help |
| Author: | slantzilla [ Wed Jan 09, 2013 9:06 am ] |
I've shifted my 198 rod/steel crank motor at 6700 on more than one occasion, and 6500 on a lot of them. Your mileage may vary. |
| Author: | jhdeval [ Wed Jan 09, 2013 3:53 pm ] |
Quote: What would be max rpm and stay dependable ??
When you ask flywheel not flex plate what do you mean? The way I understand it the engine is connected to the transmission through a flexplate/flywheel connection.
| Author: | Doc [ Wed Jan 09, 2013 3:59 pm ] |
He wants to run a manual shift trans so: "flywheel, not a flexplate" will be used, in that application. (that's how I read it) DD |
| Author: | M-Tech Tom [ Sun Jun 23, 2013 7:28 am ] |
I hope this does not violate the rules but just to let you know, we now have rods for the cast cranks in stock.
