It is currently Thu Nov 26, 2026 3:37 pm
PostPosted: Thu Dec 20, 2012 7:47 am
Car Model: 1964 Valiant V200
For a low-rpm motor (redline 5000-5500 rpm max), what is the best method of oil control? I'm more concerned with starvation while cornering than I am with power gains although any added power will be a bonus.
I am planning to braze some baffles in the stock pan, I might even section and fabricate some side kick-outs.
But my real question is concerning the cost/benefit of scrapers and windage trays.
Mike Jeffries can sell me a windage tray for $189 with all the hardware.
The guy in Florida can sell me some slick scrapers for $89
The cheapskate in me thinks that $89 beats out $189 any day, but if the windage tray will give more benefit, it might be worth saving a little more.
PostPosted: Thu Dec 20, 2012 8:28 am
Mike also sells scraper kits, they are just a little more labor intensive than Johnson's. Johnson's will need fitting, just not as much as Mike's. Mike's is a ton cheaper though.
I have a Jeffrey tray and Johnson scraper in my motor. For a street only motor I would not bother with a tray. It just doesn't do that much in the RPM range a street motor runs in.
PostPosted: Thu Dec 20, 2012 9:16 am
Thanks. I like the Johnson scrapers because they have trap doors in them, do the Jeffries ones? I will have to call Mike and ask about his. I just asked him about Windage.
PostPosted: Thu Dec 20, 2012 9:32 am
Baffles, trap doors and kickouts are best for road course purposes..
I have a baffle made in my ruster Pan along with a tray and scraper.
It's for a drag only car.. but you will get the idea..
Info links below.
http://www.slantsix.org/forum/viewtopic ... c&start=45
http://www.slantsix.org/forum/viewtopic ... c&start=60
http://www.slantsix.org/forum/viewtopic ... c&start=75
http://www.slantsix.org/forum/viewtopic ... c&start=90
Hope this is helpful.
PostPosted: Sat Dec 22, 2012 2:41 pm
The baffels in the pan should take care of any problems with oil starvation,if you add depth to the pan it will help also, a windage tray will give you H P at higher RPM you will probably see a benifit if your making H P over 5 grand. If you don,t want to spend $200 and your handy with sheet metal build one your self like I did here is a picImage
PostPosted: Sun Dec 23, 2012 8:38 pm
I have 1 scraper,a windage tray,deeper pan and baffles.think they work.
PostPosted: Thu Jan 03, 2013 9:44 am
Thanks guys, lots to think about. I might just stick with the scrapers based on the cost/benefit ratio, as well as modify the pan.
Users browsing this forum: Ahrefs [Bot], malrv1 and 5 guests
