It is currently Thu Nov 26, 2026 3:37 pm
 Post subject: Holley 1barrel numbers
PostPosted: Wed Jan 02, 2013 1:47 pm
Can someone help me with a parts number book? I need to identify which model of the 1920 Holley used on a 1976 feather duster, with manual a833od.
Also, the vacuum amplifier, as these were not only one year parts but differ between auto and manual.
Dart lite info also works.
I just need the numbers to verify so that the feather duster's clone by Doug and EGR with wider throat which start at startup work in harmony, as I am to understand it, the carburetor's vacuum circuits open switches at 'programmed values' aka as heat,opens signal vacuum valves.
Please help.
Thanks
Slant six should have stayed in production.
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot], malrv1 and 4 guests
