| 1969 Dodge Dart 225 https://slantsix.org/forum/viewtopic.php?t=50687 |
| Author: | Mike Slant [ Tue Jan 01, 2013 5:56 pm ] |
| Post subject: | 1969 Dodge Dart 225 |
I have a 1969 Dodge Dart 225 engine and 904 automatic transmission...The engine has been sitting for years and I want to get it back into running condition...It has only 38,000 original miles on it...I plan on putting the engine and trans combo into my 1940 Plymouth Business Coupe...The car will have a stub frame ahead of the firewall and a beam axle from my 1956 Dodge 1/2 ton pickup with parallel leaf springs gasser style...This is just a street car with no drag racing anticipated...I do want a Super Six intake manifold and tube headers, and a 4.10 rear gear...what kind of cam do I need to give low/mid range punch ??...I want to have a decent idle and top end is unimportant...this car is strictly entertainment on the street...I want to rebuild it close to stock...anybody have ideas ?? |
| Author: | 64ragtop [ Wed Jan 02, 2013 6:51 am ] |
Welcome to the forum. Sounds like you already have a plan, only one thought comes to mind. 4.10 is a mighty low ratio for a slant. They don't like to rev very high and won't make much power or last very long in anything like stock form, if you twist their tail. The slant is more of a torque maker than most, and with that low a rear gear your top end won't be much. You did say it's for street, not race, so I'd recon it would pull real good stoplight to stoplight. Not that anyone still does that ATB BC |
| Author: | Mike Slant [ Wed Jan 02, 2013 11:11 am ] |
I really don't plan on going more than two or three zipcodes from my house with it, but if a 4.10 is too steep even for that, do you think a 3.9 or a 3.55 would be better?...I still have to scrounge the rear...I think the stock Plymouth rear is maybe a 3.55 and it may be too fragile...Are there any special cam grinds available from Mopar or do I have to look elsewhere?...I think my /6 has a forged crankshaft if that helps. |
| Author: | Rick Covalt [ Wed Jan 02, 2013 1:12 pm ] |
3.55 would be much better than the 4.10 if this is a street car. Without and overdrive, the 3.91 & lower gears will get old really quick. Rick |
| Author: | wjajr [ Thu Jan 03, 2013 4:19 am ] |
What size tire do you plan on using? Once you know tire size, you can utilize an online driveline calculator to pick a rear gear that matches the torque curve of a stock or modified slant. |
| Author: | Mike Slant [ Thu Jan 03, 2013 6:21 am ] |
I haven't chosen any tire sizes yet, but I think a P235/70R 15 is the largest that will fit under the fenders...If I'm able to locate a Ford 9" rear, or even an 8.8" rear I can select a rear gear easily....the car is still in the "barn" after not running in over a dozen years....the old flathead might still run, but the front suspension is totally worn out....lots of $$$ to rebuild....so this is why I want a beam axle up front...I'm looking for a /6 street cam, because the engine will be ready to go before I install the beam axle and do any other work to the car...it's not going to be a race car, just a street driven hot rod that looks like a 1960s gasser....I think the old coupe will be different with a /6 up front rather than another ( yawn !) V8. |
