It is currently Thu Nov 26, 2026 2:39 pm
 Post subject: not sure what to do
PostPosted: Mon Dec 31, 2012 9:49 pm
well the subject says it all. the motor on one of my trucks has a cracked block i think because there is a streak of jb weld about the same size as a football outline right under the manifolds. not really sure if there is any cracks under it or what. but im with the group of people with the mind set that if it aint broke dont fix it as in i dont really want to replace the motor till i have too :lol: and i want to upgrade the motor somehow like an upgraded intake headers or dutra dual to get it to breathe abit better and possibly some minor headwork. my only reasoning for upgrading it would be that when that motor craps out im thinking i will replace it with another slant 6 (i love the motors!) and then just take off all the parts i put on the bad one and put it on the newer one or i will get a v8 but even then i have another slant six for parts interchange. so what do you guys think should i just leave the motor as is and just get new parts for the new motor when i put it in and stockpile a horde of parts overtime for the new motor or get the parts for it now and take it all off when the motor goes kaboot for the new slant six i put in it.
OR i have read some stuff about locknstitch awhile back and you use it to make a mostly permanent repair on the block their website has more info on it. it seems like a really good block repair option.
but im just all confused on what to do for said motor problem what do yal think
65 dodge military d200 225 /6
66 dodge d100 225 /6
PostPosted: Mon Dec 31, 2012 10:08 pm
Site Admin
If I had that engine, and it was running, and all was fine with it right now, I'd leave it alone. Don't set a wrench to it until you must, or when you replace it.
Such an engine will likely start sucking you into project creep until you have some actual money in it. That you should avoid. Spend your money on something you plan to keep.
I wouldn't even attempt a manifold swap. You may start backing Heli-Coils out of the head, and then find yourself pulling the head, and once there... See what I mean?
Get your plan together for your new engine, start with something that will be serviceable, then experiment with stitching the old block up. If it doesn't work, your out very little.
Just what I'd do...
2¢
CJ
PostPosted: Wed Jan 02, 2013 9:35 am
Vote #2 on finding a different engine and spending your time & $$ on getting that engine ready to swap-into the truck.
Any time / $$ spent on a cracked engine block, is a waste...
PostPosted: Wed Jan 02, 2013 5:31 pm
thanks for the tthoughts on this! :) now i gotta decide on what motor. i really like the slant six but the i would like to have a v8 in it because it will be a mostly offroad vehicle. my thoughts on a motor would be an international 345 or a mopar 318 to 383 anybodies input on what motor? it will be with a np435 4 spd tranny unless one came with the motor
also im gonna put like 410s or higher in the front and rear because i will be either mudding alot or pulling out logs for money
PostPosted: Fri Jan 04, 2013 4:02 am
It's a free country... you are welcome to put in whatever engine you like.
But if it is torque you're after (and it sounds like that's the goal for log pulling and mudding) then the slant has it in spades.
- Mac
Users browsing this forum: Ahrefs [Bot], DuckDuckGo [Bot] and 2 guests
