Slant Six Torsional Strength
https://slantsix.org/forum/viewtopic.php?t=50709
Author:  tackitt [ Fri Jan 04, 2013 4:45 pm ]
Post subject:  Slant Six Torsional Strength
I asked this question a couple of years ago but never heard.
The Slant Six was designed to be very robust to the point that it can be used as a structural member of the chassis.
My question: Does the aluminum block have the same capability?
I would really like to know.
Ben
Author:  slantzilla [ Fri Jan 04, 2013 7:31 pm ]
I personally wouldn't trust one but I have no solid data to prove that claim.
Author:  CNC-Dude [ Sat Jan 05, 2013 12:18 am ]
I don't think they are either, their just a die cast part, and don't have extra reinforcing ribs or much extra beefiness to them at all. Especially not having a solid deck surface.
Author:  ceej [ Sat Jan 05, 2013 12:25 am ]
The only example would have been the Lotus. That was an Iron block.
CJ
Author:  Old6rodder [ Sat Jan 05, 2013 10:45 am ]
Bingo, one side of the structural "box" of moncoque concept is missing.
As in a truss, all components must be represented or it's like a chain with a missing link. ie, the rest of the links can't do their jobs without it.
Author:  Dart270 [ Sun Jan 06, 2013 8:52 am ]
I agree. Use an iron block if you want that kind of structural support. Note that an alum block with caps is 77-79 lbs vs. 165-169 lbs for a mid-60s - mid 70s iron block. Thus, there is about the same volume of material in the alum block compared to the iron block (2.7 g/cc for alum and 7.9 g/cc for steel/iron). Aluminum is less rigid than iron and its fatigue strength is quite a bit lower. If the alum block had more material, or a lot of gusseting, maybe...
