170 spark plugs
https://slantsix.org/forum/viewtopic.php?t=50717
Page 1 of 1
Author:  Valleyant [ Sat Jan 05, 2013 7:43 pm ]
Post subject:  170 spark plugs
Hi,
About to get the '60 170 going and collecting some tune up parts. I assume the NGK # ZFR5N are ok to use in this motor, correct? Going to do a stock tune with the one barrel for now to excercise this old valiant.
Later I will add the appropriate plugs for the H-pak stuff.
Also I am not sure if this is the original '60 head (it does have the spark plug tubes, at least its a drool head :) ) yet but I need to feel for the sparkplug counterbore if removing the spark plug washers IIRC and if there is no counterbore leave the washers on. any advice is appreciated! Thanks
Author:  Dart270 [ Sun Jan 06, 2013 8:43 am ]
Those plugs should work fine on a stock build motor. I have never tried those, and tend to use NGK GR4 in stock and medium buildup apps.
I am not an expert on those really early heads, but I think it doesn't matter whether you leave the washers on or take them off. If you have drool tubes (yes), means that removing the washers will prevent tearing up the tubes over time. I ran the washers for 10-15 yrs before someone (Dan) posted about this, then I started pulling them off. The reduced tube wear was the only discernable difference I could see.
Author:  Valleyant [ Sun Jan 06, 2013 9:05 am ]
Thanks Lou! :)
