It is currently Thu Feb 27, 2025 2:39 pm
 Post subject: engine overhaul
PostPosted: Fri Feb 28, 2003 11:43 am
can someone let me know how kanter auto overhaul kit are good or bad ?or aother place to get a kit thank you :o
PostPosted: Fri Feb 28, 2003 1:07 pm
I posted a very similar question a little over a week ago and didnt get a response, but here is what i have turned up and what i got from SS.com. Northern Auto Parts has an online catalog that lists a master rebuild kit, but you have no option to upgrade the cam or oil pump. You can upgrade to moly rings and a Fel-Pro gasket set. Performance Automotive Warehouse also supposedly sells master rebuild kits for the slant. However, they do not have an online catalog so you will either need to order their catalog or look for their advertisements in the Mopar Magazines.
I have not heard of the Kanter rebuild kits, so i cant help you there. Good luck! :)
The "Silver Bullet"
87 Ram D150
PostPosted: Fri Feb 28, 2003 1:46 pm
www.kanter.com
Users browsing this forum: Semrush [Bot] and 22 guests
