It is currently Thu Nov 26, 2026 7:27 am
 Post subject: 170 slantillac update...
PostPosted: Sun Dec 30, 2012 3:16 pm
Hey all..
Figured out why she wasn't firing with the new cap.. Some dolt (me) mislabeled the towers and was one set of plug wires off.. =D
With new plugs, wires, cap and rotor she still runs like a dog.. Give her a half mile to get up to speed and she glides.. Get going up any decent hill and she's more like crawl-speed..
After a bit more investigation, I realized I have a Carter BBD on a 1bbl adapter and 1bbl intake.. Not wise, I know, but it's what it came with.
Will I see better driveability slapping on the extra, known good Holley 1920 I'm borrowing?
If it helps, we only got 90psi in the hole, so maybe its just a tiiiiiired slant.. This is before I ran all the valves, though.. Never done it before, followed the procedure on here and ran 'em hot.. It was messy, but they all appear to be on spec, now.. Now she purrs like a kitten..
The 2bbl is definitely running it rich-- new plugs were sooty black..
Any thoughts?
Raj
Raj
73 Plymodgillac http://www.flickr.com/photos/57785272@N ... 353884166/
67 Valiant V-100 (170ci, 3-on-the-tree, and in exploded view - suspension)
67 Barracuda Coupe (RIP 04-01-2001 to 04-25-2009)
PostPosted: Sun Dec 30, 2012 3:46 pm
Make sure the choke opens all the way when it is warm.
Your car looks very cool.
PostPosted: Mon Dec 31, 2012 7:31 am
Cool car!
It's always good to see when someone let their fantasy car come to life! :D
Olaf
Aspenized
PostPosted: Mon Dec 31, 2012 3:50 pm
Yep, get the right carb on there before anything else. Get that engine running and dialed in and drive it. I wouldn't be surprised to see the compression in that cylinder go up after it gets a chance to burn off all that carbon and clear its throat. Seen it happen on a few engines that were thought to be tired, but they were just gunked up from not running correctly for some time.
That Holly 1920 will be fine although I prefer the BBS myself, but it's a preference thing.
PostPosted: Tue Jan 01, 2013 6:00 pm
Good news at the junkyard today--
Found a /6 73 Dart and robbed it of its window trim front and back, a 1bbl aircleaner, the kickdown linkage and accelerator cable.. This car was a total creampuff and it was so sad to see it in the junkyard!! I even got the factory electronic choke.. I passed on the vacuum accelerator that was plumbed into it because I don't run power anything in the car.. But, it was cool to see a car so unmolested.. Bummer part is somebody robbed the 1bbl off it before I had a chance to so I have no idea what it was running.. The 1bbl I have is a loaner..
Raj
Raj
PostPosted: Wed Jan 02, 2013 5:58 am
Get that one bbl carb on your /6 and dial it in...double check the timing, dwell, and idle speed....drain and refill the crankcase with fresh oil and a new oil filter...substitute one quart of motor oil for a quart of Marvel Mystery Oil...now take her on the freeway at freeway speeds for about half an hour one way...this will get everything hot and give the MMO a chance to penetrate behind the piston rings and loosen them up from all the carbon created by running too rich...it just might even restore some lost compression too...give it a shot...you will be happy with the way it runs....and I love the fins !!!
1956 Dodge 1/2 ton w/318,..1952 Ford 1/2 ton w/Hemi,..1940 Plymouth Business Coupe w/flathead six, dual carbs, and headers
PostPosted: Wed Jan 02, 2013 7:26 pm
1bbl is on, but suffering from a slight leak at what I presume is the bowl gasket (ie: the four screws that hold the big cover on a Holley 1920).. Ran it and she shifts much better (hurray for kickdown, even if I'm sure its adjusted wrong.. Not sure if I'm even hitting 3rd gear, but the shift into 2nd is firm..).. Throttle response is more immediate and without bog, though it also doesn't make too much more power.. Definitely in for an oil change and a wheel alignment asap..
Thanks again, all, for the help.. More info when I get some more work done on her..
Raj
Raj
PostPosted: Sun Jan 06, 2013 1:02 pm
So, getting ready to install Trailbeast's HEI setup (from ForAbodiesOnly, www.classichei.com) and I realized.. Dang it. I have a points distributor on this car.. Far be it from me to assume anyone changing motors would retain the electronic distributor.. Harrumph.. So, I'm glad I grabbed a "spare" electronic distributor from the junkyard when I was out there.. I sent it off the Duster Idiot for the recurve and am excited to see how much the car cleans up in terms of idle quality, etc..
I also found out the reason why there's a giant plug and adapter on the front of the engine (and why I have no temp sensor).. Dang it, I'll need to yank that so I can run the factory temp sensor.. But, of course, it looks quite solid in place.. Worried that if I crank on it with pair of pliers that it'll destroy the threads or snap off.. Then I'll be stuck drilling into the water passages of my motor.. ick.. That 225 swap is looking better and better if only because I know I can get the motor ready to go on a stand.. :)
Raj
Users browsing this forum: Google [Bot] and 7 guests
