| Need to Remove Harmonic Balancer Center Bolt https://slantsix.org/forum/viewtopic.php?t=50722 |
| Author: | jrdoj [ Sun Jan 06, 2013 12:11 pm ] |
| Post subject: | Need to Remove Harmonic Balancer Center Bolt |
I have a later model engine, and I need to pull the harmonic balancer. It appears the large 1.25" bolt at the center that I typically use to crank the engine back and forth needs to come out. What's the best way to achieve this without an impact driver? |
| Author: | Pierre [ Sun Jan 06, 2013 12:26 pm ] |
If its in the car you can place a long wrench / breaker bar on it then have the other end firm against the floor or the radiator brace. Then bump the starter over. Pull a coil wire so it won't start. Or use a pry bar in between the converter or flywheel teeth. If it's out of the car you need to stop the crank from turning. Maybe put two longer bolts where the flex plate bolts would go and stick a bar through them. Or if flexplate is still on you can put something up against it. |
| Author: | jrdoj [ Sun Jan 06, 2013 4:10 pm ] |
It worked! And it was still on the car - thanks for explaining even though I left that detail out. Much thanks, Pierre. |
