It is currently Wed Nov 25, 2026 6:07 pm
 Post subject: Need some Holley info
PostPosted: Tue Jan 08, 2013 12:32 pm
Hi, d like to know a little bit more about my two barrel Holley. Its an american model (Holley USA), 36/36, and I knew that this model came in V8 Ford trucks (f600 and f100).
In my country there is a factory that builds holley carb under license, but my carb is an original Holley USA.
Is there any way to identufy it?
The fuel bowl is the one that comes with a little "window" to check the fuel level... Its the old school fuel bowl I guess....
Mopar or no Car!
PostPosted: Tue Jan 08, 2013 3:01 pm
Does it look like this?
PostPosted: Tue Jan 08, 2013 7:49 pm
No, the carb is this:
My previous carb was almost the same as this, with the only difference that the needle was in the fuel bowl, outside (this has to be regulated from insde).
The number in the main body of that carb was 3225, it means that it was used in the 67/71 v8 ford 600...
Id like to know in which car or truck was this carb used, accordin to its number (5292).
Is it possible to know of how many CFM is it?
Mopar or no Car!
PostPosted: Tue Jan 08, 2013 9:29 pm
6 Pack Dart
What are the numbers on the front of the choke area and on the flat portion behind the actual carb opening.
Richard
PostPosted: Wed Jan 09, 2013 2:54 am
Richard
The numbers can be read in the photos. In the choke area it says:
CITE 9510 K
LIST 2013 1
In the metering plate it says: 5292.
Check:
Image Image Image
Image Image
Mopar or no Car!
PostPosted: Wed Jan 09, 2013 4:24 am
from the ford part no its a 1961 heavy truck carb. Rating is probably 500cfm, I can gather more info just take a bit for me to dig it out....The metering plate no etc does help, but its going to be from the f600 series truck. (2 1/2 ton) ie grain truck...
Probably a 272 or 292 Y-Block Ford engine....
MRO....
PostPosted: Wed Jan 09, 2013 7:33 pm
Thanks, Id really like to know where did that carb came from.
Mopar or no Car!
Users browsing this forum: Amazon [Bot] and 7 guests
