eng bracketry 225, 1969?
https://slantsix.org/forum/viewtopic.php?t=50724
Page 1 of 2
Author:  slant6 [ Sun Jan 06, 2013 4:50 pm ]
Post subject:  eng bracketry 225, 1969?
I need a picture of the brackets that attach to the block so I can attach my eng mts? TiA, Dana[/i]
Author:  Reed [ Mon Jan 07, 2013 12:46 pm ]
Do you just need pictures of where the motor mounts attach or do you need to know how all the brackets mount?
Author:  slant6 [ Mon Jan 07, 2013 5:22 pm ]
Post subject:  mts
Yes, pictures of how they look attached from block bracketry to rubber eng mt. Thank you, Dana
Author:  Danarchy [ Mon Jan 07, 2013 5:24 pm ]
what year did they change to a spool type mount? would a 1969 be the same as 1964? if so,I have an extra set.
Author:  Danarchy [ Mon Jan 07, 2013 5:36 pm ]
passengers side USA (mount removed, but thats where it bolts in. elusive and hard to photograph in car.)
drivers side USA
Author:  DusterIdiot [ Mon Jan 07, 2013 6:40 pm ]
Post subject:  Comment on removed mount picture...
The mount on the passenger side is a flat-ish channel with the rubber toward the top of the engine so the engine leans in that direction.
Author:  slant6 [ Tue Jan 08, 2013 3:26 pm ]
Post subject:  mts
Drivers side helps but other side I need help to see what it looks like also. If anyone has both sides I am interested, send pic first. Thanks for all of u guy's help, Dana
Author:  Fopar [ Tue Jan 08, 2013 3:36 pm ]
As duster idiot said the passengers side mounts with the ears the rubber bolts to is toward the top of the motor.
Richard
Author:  slant6 [ Tue Jan 08, 2013 6:06 pm ]
#2264 and 2265 should be the correct mts to buy to attach to my block bracketry, correct?
Author:  Fopar [ Tue Jan 08, 2013 6:19 pm ]
Where did you get those numbers?
#2264 and 2265
Richard
Author:  DusterIdiot [ Tue Jan 08, 2013 6:58 pm ]
Post subject:  I have...
A set of 1970 Dart brackets with Rubber in good shape I'd sell $25+ shipping...
Author:  slant6 [ Tue Jan 08, 2013 8:10 pm ]
Post subject:  mts
Richard, e-bay, 2 different sources, but they are only the engine mt (rubber with studs)[/i]
Author:  slant6 [ Tue Jan 08, 2013 8:12 pm ]
Post subject:  mts
D idiot, send pic of what u r trying to sell, thanks, Dana
Author:  Danarchy [ Wed Jan 09, 2013 7:50 am ]
Dana-I will get you a picture of the passenger side mount this evening.
Author:  slant6 [ Wed Jan 09, 2013 1:30 pm ]
Post subject:  mts
Great, thanks[/b]
Page 1 of 2 All times are UTC-08:00
