It is currently Thu Nov 26, 2026 1:33 am
 Post subject: Clifford headers
PostPosted: Mon Jan 07, 2013 10:07 am
I got a set of Clifford Shorty headers for my 68 barracuda and was wondering if anyone knew of a simple way to run the exhaust out of the engine compartment?
I mocked it all up a few days ago and noticed it looks like a real tight fit to get both those pipes running back cleanly.
Any tips are appreciated!
68 Barracuda 71 Dart
PostPosted: Mon Jan 07, 2013 11:23 pm
You answered your own question, it is a nightmare. I have a buddy who did the same thing on a Swinger. Our exhaust guy did a great job with it, but it makes it a pain to work on things.
I have the 2X1 pipe with my Cliffords. It probably gives up some power, but it makes life hella easier.
PostPosted: Tue Jan 08, 2013 12:26 am
Sure, turn them upside down and make them zoomies ;) You said out of the engine compartment, but didn't specify under or above!
On my Dual dutra duals I have 2x 2 1/4" pipes to about the trans tailshaft, then Y together and one pipe over the axle. There's less then an inch clearance to the torsion bar on one side and then about the same to the trans (or was it auto column shifter linkage?) on the other.
