It is currently Wed Nov 25, 2026 5:33 pm
 Post subject: eng bracketry 225, 1969?
PostPosted: Sun Jan 06, 2013 4:50 pm
I need a picture of the brackets that attach to the block so I can attach my eng mts? TiA, Dana[/i]
PostPosted: Mon Jan 07, 2013 12:46 pm
Do you just need pictures of where the motor mounts attach or do you need to know how all the brackets mount?
 Post subject: mts
PostPosted: Mon Jan 07, 2013 5:22 pm
Yes, pictures of how they look attached from block bracketry to rubber eng mt. Thank you, Dana
PostPosted: Mon Jan 07, 2013 5:24 pm
what year did they change to a spool type mount? would a 1969 be the same as 1964? if so,I have an extra set.
1964 Dart GT
PostPosted: Mon Jan 07, 2013 5:36 pm
passengers side USA (mount removed, but thats where it bolts in. elusive and hard to photograph in car.)
drivers side USA
1964 Dart GT
PostPosted: Mon Jan 07, 2013 6:40 pm
The mount on the passenger side is a flat-ish channel with the rubber toward the top of the engine so the engine leans in that direction.
 Post subject: mts
PostPosted: Tue Jan 08, 2013 3:26 pm
Drivers side helps but other side I need help to see what it looks like also. If anyone has both sides I am interested, send pic first. Thanks for all of u guy's help, Dana
PostPosted: Tue Jan 08, 2013 3:36 pm
6 Pack Dart
As duster idiot said the passengers side mounts with the ears the rubber bolts to is toward the top of the motor.
Richard
PostPosted: Tue Jan 08, 2013 6:06 pm
#2264 and 2265 should be the correct mts to buy to attach to my block bracketry, correct?
PostPosted: Tue Jan 08, 2013 6:19 pm
6 Pack Dart
Where did you get those numbers?
#2264 and 2265
Richard
 Post subject: I have...
PostPosted: Tue Jan 08, 2013 6:58 pm
A set of 1970 Dart brackets with Rubber in good shape I'd sell $25+ shipping...
 Post subject: mts
PostPosted: Tue Jan 08, 2013 8:10 pm
Richard, e-bay, 2 different sources, but they are only the engine mt (rubber with studs)[/i]
 Post subject: mts
PostPosted: Tue Jan 08, 2013 8:12 pm
D idiot, send pic of what u r trying to sell, thanks, Dana
PostPosted: Wed Jan 09, 2013 7:50 am
Dana-I will get you a picture of the passenger side mount this evening.
1964 Dart GT
 Post subject: mts
PostPosted: Wed Jan 09, 2013 1:30 pm
Great, thanks[/b]
