| Need some Holley info https://slantsix.org/forum/viewtopic.php?t=50745 |
| Author: | fede-valiant [ Tue Jan 08, 2013 12:32 pm ] |
| Post subject: | Need some Holley info |
Hi, d like to know a little bit more about my two barrel Holley. Its an american model (Holley USA), 36/36, and I knew that this model came in V8 Ford trucks (f600 and f100). In my country there is a factory that builds holley carb under license, but my carb is an original Holley USA. Is there any way to identufy it? The fuel bowl is the one that comes with a little "window" to check the fuel level... Its the old school fuel bowl I guess.... |
| Author: | Doc [ Tue Jan 08, 2013 3:01 pm ] |
Does it look like this? DD
| Author: | Fopar [ Tue Jan 08, 2013 9:29 pm ] |
What are the numbers on the front of the choke area and on the flat portion behind the actual carb opening. Richard |
| Author: | Mroldfart2u [ Wed Jan 09, 2013 4:24 am ] |
from the ford part no its a 1961 heavy truck carb. Rating is probably 500cfm, I can gather more info just take a bit for me to dig it out....The metering plate no etc does help, but its going to be from the f600 series truck. (2 1/2 ton) ie grain truck... Probably a 272 or 292 Y-Block Ford engine.... |
| Author: | fede-valiant [ Wed Jan 09, 2013 7:33 pm ] |
Quote: from the ford part no its a 1961 heavy truck carb. Rating is probably 500cfm, I can gather more info just take a bit for me to dig it out....The metering plate no etc does help, but its going to be from the f600 series truck. (2 1/2 ton) ie grain truck...
Thanks, Id really like to know where did that carb came from.
