| firewall foam gasket replacement? https://slantsix.org/forum/viewtopic.php?t=50783 |
| Author: | Mike_64_Valiant [ Fri Jan 11, 2013 5:12 am ] |
| Post subject: | firewall foam gasket replacement? |
I removed the steering column and the brake master cylinder from the fire wall of my 64 valiant. The think styrofoam type gaskets just turned to powder. When can I find these on the cheap or do you guys have any ideas for a replacement material? |
| Author: | Fopar [ Fri Jan 11, 2013 9:38 am ] |
I used the plastic sheet packing material, it is like a thin foam sheet that is smooth on both sides. Richard |
| Author: | FrankRaso [ Fri Jan 11, 2013 9:53 am ] |
http://www.detroitmuscletechnologies.co ... -firewall/ |
| Author: | Rick Covalt [ Fri Jan 11, 2013 9:54 am ] |
Hobby Lobby and other craft stores have white foam in sheets for about $2. I bought a couple sheets and made all mine for cheap!! |
