Best block for boost?
https://slantsix.org/forum/viewtopic.php?t=50786
Author:  RyGuyTooDry [ Fri Jan 11, 2013 12:14 pm ]
Post subject:  Best block for boost?
I have a 65 225 and a mid 70's 225, which block would be better for a turbo?
Author:  Dart270 [ Fri Jan 11, 2013 12:17 pm ]
They will both work fine, but if the 70s one is forged crank, then that one will be slightly stronger.
Author:  RyGuyTooDry [ Sat Jan 12, 2013 1:26 pm ]
How can I tell if its a forged crank? I really dont want to tear it apart to find out though... and thank you.
Author:  slantzilla [ Sat Jan 12, 2013 2:40 pm ]
Depending on what you're putting it in, the register on the cranks are different sizes too.
The cast crank came mid 1976. There should be a stamping on the pad under the alternator bracket that will give you the year.
Author:  Dart270 [ Mon Jan 14, 2013 2:09 pm ]
Doc's "blocks" article on the main slantsix.org then "articles" page can answer your questions, I believe.
