It is currently Wed Nov 25, 2026 5:59 am
 Post subject: Intake to Exhaust Bolts
PostPosted: Sun Jan 13, 2013 10:00 am
Hey guys
Just wondering if anyone knows the size of the bolts that hold the intake and exhaust manifolds together. Theyre missing from my super six setup.
PostPosted: Sun Jan 13, 2013 10:20 am
Is this the info you need?
Manifold set to Head Studs : 5/16-18 x 1/2, 5/16-24 x 3/4, 1¾ total, use sealer into head.
Check here:
http://www.dutra.org/doug/draft-webpage ... -chart.htm
Mopar or no Car!
PostPosted: Sun Jan 13, 2013 10:51 am
The ones you posted weren't the ones I need, but the right ones are listed on there. I didn't know that existed! That's great. Thank you very much!
PostPosted: Sun Jan 13, 2013 10:53 am
Hey guys
Sorry, I think you need this size: Thread size 5/16-18, 1/2 (wrench size)
Those are the three bolts that keep both manifolds together.
Mopar or no Car!
 Post subject: Actually...
PostPosted: Sun Jan 13, 2013 4:37 pm
The middle one is a stud that you use a flange nut on and the other two outboard are bolts...but they don't make the right length bolts that have threads up to the point you need...so you get two choices:
Buy the right length bolts and thread them another 1/2" with a tap and die set...or you can get a small length of all thread and nut and washer both ends (I like to use a version called D-8...i have yet to have it seize if swapping manifolds regularly.)
Good Luck,
PostPosted: Sun Jan 13, 2013 4:42 pm
I was planning on using a die and pulling the threads up further if I needed to. Guess I do need to haha.
The bolts in the current set up might be okay, they were new a year or two ago...I'll have to see once my gaskets get in and I start actually doing everything.
PostPosted: Sun Jan 13, 2013 5:29 pm
I got tired of burning that gasket of the midle!!! So, I melded a piece of iron to the top of the exhaust manifold, covering the hole...
End of the problem.
When I took manifolds out I discovered that the last mechanic had cut the bolt inside (the one nearer the head) and that why I kept burning gaskets.
Mopar or no Car!
PostPosted: Sun Jan 13, 2013 6:38 pm
Ah thats no good! I've never had issues with that one burning out but my exhaust pipe flange gasket ALWAYS burns out. It's the most frustrating thing.
PostPosted: Sun Jan 13, 2013 8:11 pm
Tell me! I got almost crazy with that thing!!! Must be the wrong aligment or the manifold weight, but I had many problems with that midle gasket... I used tons of leaks sealer.
In the other side of the world, got the same problems! Isn´t that reconforting?? :lol:
Check this:
http://www.ebay.com/itm/Slant-6-Six-Dod ... 9f&vxp=mtr
Mopar or no Car!
PostPosted: Sun Jan 13, 2013 9:03 pm
I'm gonna do my best to avoid the block off plate. I need that manifold heat on cold Canadian mornings! :P
I think I have a makeshift block off plate on my current set up, actually. I don't remember if I ended up putting one there or not. I'm thinking yes cause I'm having very poor cold temperature operation right now.
PostPosted: Sun Jan 13, 2013 9:37 pm
Thats right, in my country is common to block the exhaust off, or to use silens headers without the manifold heat. We dont need that because we dont have such extreme cold weather. That gasket is a real headache sometimes!
http://www.dodge-tech.com.ar/vb/showthr ... planchuela
Mopar or no Car!
Users browsing this forum: Amazon [Bot] and 3 guests
