I NEED HELP! Dash removal!?
https://slantsix.org/forum/viewtopic.php?t=50806
Author:  RyGuyTooDry [ Sun Jan 13, 2013 8:56 am ]
Post subject:  I NEED HELP! Dash removal!?
Can someone explalin to me how to remove my dash? Its a 1965 Plymouth belvedere. I don't know what bolts to remove, what to leave, etc.
Author:  DusterIdiot [ Sun Jan 13, 2013 9:41 am ]
Post subject:  The instrument cluster or the Dash itself?
The full dashboard will require removal of the windsheild to get at the bolts holding the back of the dash to the cowl...
Author:  Dodge33 [ Wed Jan 23, 2013 5:30 pm ]
Also remove the lower plastic kick panel's, underneath the lower dash frame, and loosen one bolt per each side of the dash, then with all the 5-6 small bolt's removed, , under the windshield/rubber, as per mentioned in the previous post)
the dash may have a brace too, under the middle of the dash to the cowl, so check for that too, and dashboard should be able to be removed.
