225 manifold
https://slantsix.org/forum/viewtopic.php?t=50820
Author:  slant6 [ Mon Jan 14, 2013 5:42 am ]
Post subject:  225 manifold
My manifold has 2 hard line fittings on each side approx center. One side it broke off inside and it floats in there but can't get it out. Is these 2 fittings attach to my single barrel carb to suck air? Also can I just tap them and run partial hard line then hose? Thanks Dana
Author:  mpgmike [ Mon Jan 14, 2013 9:49 am ]
Even a bad picture can be better than a good description. Can you oblige?
Mike
Author:  Reed [ Mon Jan 14, 2013 10:11 am ]
Intake or exhaust manifold? If exhaust manifold, you likely have one of the somewhat rare (at least in the US) anti-icing air heating systems that ran a tube through the exhaust manifold to pre-heat the air going into the carb. See HERE.
