Engine oil pressure reading for a slant
https://slantsix.org/forum/viewtopic.php?t=50829
Page 1 of 1
Author:  crickhollow [ Mon Jan 14, 2013 1:54 pm ]
Post subject:  Engine oil pressure reading for a slant
Is 45 to 50 psi an acceptable oil pressure reading for a 160 hp Slant?
Author:  valiant200kid [ Mon Jan 14, 2013 1:58 pm ]
from my understanding thats more than enough if i recall right the rule is 1lbs for every 100rpm
Author:  Joshie225 [ Tue Jan 15, 2013 8:25 am ]
45-50 psi is excellent.
Author:  Danarchy [ Mon Aug 05, 2013 8:47 am ]
With my mechanical gauge I read 49 psi constant. No heavy fluctuation with engine at full temp or high speed? Why would that be? or is that normal on a rebuilt engine? (right at 500 miles on it) Running Rotella 15w-40 right now(100+ degrees in Texas), switching to 10w-30 on initial change.(and will run 10w-30 here on out)
Author:  kxracer728 [ Mon Aug 05, 2013 9:31 am ]
On my truck the needle goes just above the 3rd notch on the gauge and will fluctuate a little below the 3rd notch while driving...I'm wondering if that's reasonable oil pressure?
I assume that each notch on the gauge maybe 10 psi of pressure but i'm not sure?
