| '66 crank - I need a dimension and comfirmation please https://slantsix.org/forum/viewtopic.php?t=50839 |
| Author: | Sprag [ Wed Jan 16, 2013 12:00 pm ] |
| Post subject: | '66 crank - I need a dimension and comfirmation please |
I just got off the horn with my machinist and he gave me the dimensions of the converter snout bore/recess in the rear flange of my '66 crank and it seems weird. I plan to have the recess machined now to fit a '68+ converter later and the dimensions he gave me seem strange, like there isn't much meat there on the hub ring: Bore depth: .625" Hub Ring OD: 1.960" Hub Bore ID: 1.550" A member here thought it should be 1.815" ID for the larger '68+ converters but wasn't 100% sure so I need to confirm this, it seems like machining to that ID dimension won't leave much left if the existing hub ring OD is only 1.960". (1.960" - 1.815" = .145" / 2 = .0725" hub ring width remaining??) Am I making sense here?? THANKS |
| Author: | robertob [ Wed Jan 16, 2013 12:46 pm ] |
That is right. The later crank has a larger OD too, and a larger hole in the flexplate. 2.16 is the number in the chart. http://www.slantsix.org/articles/parts-matrix/jpg.htm |
| Author: | Sprag [ Wed Jan 16, 2013 9:26 pm ] |
Thanks, that solves that "problem". Looks like we'll be keeping the grinder, I really wasn't looking forward to the switch to an automatic anyway! |
