| Possible Camshaft Scrap https://slantsix.org/forum/viewtopic.php?t=50927 |
| Author: | jhdeval [ Fri Jan 25, 2013 7:24 pm ] |
| Post subject: | Possible Camshaft Scrap |
Okay so here are a couple of pictures of a camshaft I want to use as a core for a regrind. Does this look like damage and if so does it look to far gone? This is 2 different spots. ![]()
| Author: | Fopar [ Fri Jan 25, 2013 7:36 pm ] |
looks to me like the casting had some voids. Richard |
| Author: | DusterIdiot [ Fri Jan 25, 2013 10:41 pm ] |
| Post subject: | Lol... |
If you ask for something fairly radical, those will be gone after they reduce the base circle and put the steeper lobe on the core...(how do you like 250@.050?) -D.Idiot |
| Author: | jhdeval [ Fri Jan 25, 2013 10:59 pm ] |
250 sounds a bit radical for this build. I am more in the 236-240 range this time around. Want this to be a streeter. |
| Author: | Doctor Dodge [ Sun Jan 27, 2013 9:00 am ] |
That amount of wear is common on a high mileage SL6 cam and it will "grind-out". More important is wear on the fuel pump eccentric, most regrinders do not like to regrind the FP eccentric so any wear there is a problem. DD |
| Author: | Greg Ondayko [ Sun Jan 27, 2013 10:25 am ] |
Quote: That amount of wear is common on a high mileage SL6 cam and it will "grind-out".
Could You chuck it up in a lathe and Do the Fuel Pump eccentric by your self with some Emery cloth?More important is wear on the fuel pump eccentric, most regrinders do not like to regrind the FP eccentric so any wear there is a problem. DD Greg |
