main bearings
https://slantsix.org/forum/viewtopic.php?t=50932
Page 1 of 1
Author:  duck0121 [ Sat Jan 26, 2013 11:25 am ]
Post subject:  main bearings
sealed power and clevite both are hanging out of main journels any ideas or thoughts this is a 67 225 block[img]/Users/JHouston/Pictures/iPhoto%20Library/Masters/2012/12/11/20121211-174504/IMG_0415.JPG[/img]
Author:  ceej [ Sat Jan 26, 2013 3:08 pm ]
You will need to host the photo someplace like photobucket.
Can't see the photo.
Author:  Doctor Dodge [ Sun Jan 27, 2013 9:02 am ]
Sounds like forged crank bearings in a cast crank engine.
Vote #2 for a photo.
Author:  Charrlie_S [ Sun Jan 27, 2013 3:21 pm ]
He did have pics over at FABO but they are gone now. It did look, to me, like a cast crank block with forged main bearings.
Author:  duck0121 [ Mon Jan 28, 2013 12:43 pm ]
Post subject:  mains
go to john henry houston on face book and you can see the way the bearings are sitting the block
Author:  Joshie225 [ Mon Jan 28, 2013 1:26 pm ]
Post subject:  Adding photos, changing display size, making links
http://www.slantsix.org/forum/viewtopic.php?t=4434
Author:  walpolla [ Mon Jan 28, 2013 1:32 pm ]
Post subject:  Re: mains
No, not everyone is on that site.
Rod :roll:
Author:  Charrlie_S [ Mon Jan 28, 2013 4:46 pm ]
Rod :roll:
X2, I don't do facebook. I spend enought time here.
Author:  duck0121 [ Mon Jan 28, 2013 5:35 pm ]
<img src="http://i1353.photobucket.com/albums/q661/duck0121/IMG_0414_zps424da3b1.jpg" border="0" alt="slant 6 bearings photo IMG_0414_zps424da3b1.jpg"/>
Author:  Doc [ Tue Jan 29, 2013 9:12 am ]
Yes... you are showing a forged crank main bearing insert. (2 oil feed holes)
Go get a set of mains for a 76 and newer SL6, that should fix it.
(also check your con rod bearings... those are also different for the cast crank engine)
On ebag
Author:  duck0121 [ Tue Jan 29, 2013 2:28 pm ]
but the block is marked 67 225r
Author:  Doc [ Tue Jan 29, 2013 2:59 pm ]
Could the "r" stamping be the letter "E"??
Author:  duck0121 [ Wed Jan 30, 2013 10:13 am ]
ordered some new bearings and the block does have two oil passages thax for the help
