It is currently Tue Jun 09, 2026 1:04 pm
 Post subject: Tire/Wheel thoughts
PostPosted: Sat Jan 26, 2013 2:14 pm
I'm doing a disc swap and front end rebuild, which swaps me to BBP and requires new rims and tires. Here's what I'm looking at:
225/60R15 on 15x7 rims
Here's my question:
What kind of backspacing might this require ('71 Dart Swinger with '74 disc parts up front, 7.25 with 10" drums out back)? And with that said, what length studs should I look at installing (the current studs extend 1" beyond the drum/rotor hub)?
Thanks for the help!
My Dart
GO VOLS!
It's not rocket science, we're just splitting atoms.
 Post subject: Yep...
PostPosted: Sat Jan 26, 2013 9:18 pm
Stock studs should be fine if the backspacing is stock and no adaptors were used.
Backspacing is about 4.25" to 4.5" depending on style of rim and application/rim width.
PostPosted: Sun Jan 27, 2013 7:43 am
Thanks D.I.
I'll test fit everything with stock studs and go from there.
My Dart
GO VOLS!
