| I talked to John Cox today....... https://slantsix.org/forum/viewtopic.php?t=5098 |
| Author: | slantzilla [ Wed Feb 26, 2003 6:54 pm ] |
| Post subject: | I talked to John Cox today....... |
and got me a set of those sweet 1.6 roller rockers on the way. Gonna make a nice addition to "Son of Slantzilla". Thanks John! |
| Author: | Jopapa [ Sat Jul 05, 2003 10:26 pm ] |
Dug this one up Did you notice much of a performance increase with the roller rockers? I'd love to put roller lifters and rockers in when I rebuild the valvetrain in the '70 I'm working on, but the prices I've seen (note: I don't know how much Cox parts are since i haven't been able to fond pricing) of other parts are insanely rediculous. So is it worth it? My goal is to build up a pretty formiddable street rod. |
| Author: | 87Slant_sickness [ Sun Jul 06, 2003 2:38 pm ] |
Dennis, didnt those Rockers kill the guides n stuff in your head? Justin |
| Author: | slantzilla [ Tue Jul 08, 2003 3:42 pm ] |
General consensus is that they should not be run on the street without an oil spray bar. |
| Author: | Jopapa [ Thu Jul 17, 2003 8:54 pm ] |
Quote: General consensus is that they should not be run on the street without an oil spray bar.
How easy is it to make an oil spray bar? I would assume it'd be a piece of cake, aside from having to tap it into an oil channel on the block or head somewhere.
| Author: | Doc [ Fri Jul 18, 2003 8:45 am ] |
| Post subject: | Rockarm Spray Bar (Oiler) |
Quote: Quote: General consensus is that they should not be run on the street without an oil spray bar.
How easy is it to make an oil spray bar? I would assume it'd be a piece of cake, aside from having to tap it into an oil channel on the block or head somewhere.http://www.dutra.org/pictures/engine/pa ... -oiler.jpg DD |
| Author: | Jopapa [ Fri Jul 18, 2003 11:26 am ] |
| Post subject: | Re: Rockarm Spray Bar (Oiler) |
I use a piece of hard line and weld (braze) it into the valvecover right over the rockerarm tips. The tricky part was finding the location for all the spray holes, I mocked-up the rocker arms assembly with little balls of clay on each tip then cranked the engine through a few rotations. The clay left marks at the places where I needed to drill the small .025 holes.
So where do you get the oil for it? Did you tap into the cylinder head or block somewhere?
| Author: | Doc [ Fri Jul 18, 2003 12:45 pm ] |
I come right-off the oil pump with a "T" fitting into the tapped boss under the oil filter.DD |
| Author: | Jopapa [ Fri Jul 18, 2003 2:19 pm ] |
Groovy. I've already got a T fitting on there for both the idiot light and the mechanical oil pressure gauge. One more T fitting couldn't hurt DD |
| Author: | Doc [ Fri Jul 18, 2003 2:56 pm ] |
If you ever have the engine out and rebuilt it is nice to drill and tap the boss at the end of the main oil galley so you have another location to pick-up oil pressure.DD
| Author: | mighty mouse 63 [ Sat Jul 19, 2003 1:19 pm ] |
Hey Doc using your guide "playing with blocks"in my rebuild , curious as to to what size drill/tap you used for the above modification? |
| Author: | Jopapa [ Sat Jul 19, 2003 8:22 pm ] |
Quote: Hey Doc using your guide "playing with blocks"in my rebuild , curious as to to what size drill/tap you used for the above modification?
I'm guessing by seeing the brass fitting there, it's a 1/4" NPT. Do I get a cookie if I'm right? |
| Author: | Doctor Dodge [ Sun Jul 20, 2003 3:10 pm ] |
No cookie for you... I tap the rear galley boss to 1/8 NPT, that uses a 5/16 drill but I tend to first drill a 1/4 hole, then step-up to 5/16 & drill about 3/4 thru, that helps with keeping a tight, tapered pipe thread. DD
