| cylinder head identification https://slantsix.org/forum/viewtopic.php?t=50987 |
| Author: | Bing Kunzig [ Fri Feb 01, 2013 5:17 pm ] |
| Post subject: | cylinder head identification |
How does one tell the difference between a '60-'62 slant head and one from '63 to '74? |
| Author: | hyper_pak [ Fri Feb 01, 2013 5:29 pm ] |
| Post subject: | Casting Numbers |
Check the casting number under the valve cover. There is a listing in the articles tab "Table listing Heads, Crank & Block variations" That has most of the common numbers. |
| Author: | fede-valiant [ Mon Feb 04, 2013 8:29 pm ] |
aren´t they equals anyway? |
| Author: | Sprag [ Mon Feb 04, 2013 8:41 pm ] |
Quote: aren´t they equals anyway?
Other than the improved chamber design change in '68 I dunno EDIT: Oh, there is the hardened exh seats in '72+. |
| Author: | Reed [ Mon Feb 04, 2013 10:30 pm ] |
Combustion chamber redesign, drool tubes vs. peanut plugs, rear rocker shaft bolt change, air injection tubes, square vs. rounded valve cover, extra ports in the water jacket for coolant operated vacuum switches and sensors, different sized coolant temp sending units. Some of the various differences between 1960 and 1987. |
