Auto Trans.Linkage
https://slantsix.org/forum/viewtopic.php?t=50992
Page 1 of 1
Author:  Philip's66 [ Fri Feb 01, 2013 8:14 pm ]
Post subject:  Auto Trans.Linkage
I am trying to go from flloor shift to column shift. I originally had column shift but I went to floor shiftw/manual valve body.Now 30 years later I want to put it back. :? :oops: Needless to say I do not have linkage. Not even the shifter on the column. I have not located a picture of the llinkage and was wondering if someone here could help me. I am pretty good at fabrication but I know there are some other parts I may need . E bay may be a source but if I know what to look for it may be easier for me to fabricate some of the linkage.
I figure with the experts and experienced mechanics here You could point me in the right direction.
Author:  Charrlie_S [ Sat Feb 02, 2013 5:40 am ]
A year and model, would help.
Author:  Philip's66 [ Sat Feb 02, 2013 7:15 am ]
It's Hell getting old.
1966 Dodge Dart.
Author:  Philip's66 [ Sat Feb 02, 2013 8:12 pm ]
Post subject:  pictures
Would I be able to find pictures of the linkages in a service manual. I am considering buying one off of ebay . Does anyone know if they have pictures in there for the literary challenged like me?And am I on the right track?
Author:  bigslant6fan [ Sat Feb 02, 2013 10:22 pm ]
Did '66 have a throttle cable,or the "side twist linkage" ? I have a '65 and a 67 manual.
Author:  Fopar [ Sat Feb 02, 2013 11:42 pm ]
I think 66 was the first year for rod shift.
Richard
Author:  Charrlie_S [ Sun Feb 03, 2013 5:55 am ]
1966 was the first year for the rod shift linkage.
A service manual is always a good thing to have, if you are going to work on your own car. And, yes, the 66 plymouth SM soes have a picture of the linkage.
Do you have the correct steering columm, and just missing the lever that comes off the columm, or has the columm been changed to one, that does not accept the lever (floor shift columm)?
Author:  Philip's66 [ Sun Feb 03, 2013 7:36 am ]
Post subject:  Linkages
I have the correct column-it is original .when I was young& dumb I removed the shift lever so the dash appeared cleaner. I am definitely going to get theFSM then. I have a BBD on the motor w/cable throttle linkage. I'll get the kickdown setup and the correct shifting set up and get back on the road soon.
Author:  Charrlie_S [ Sun Feb 03, 2013 7:56 am ]
I might have a shift lever. I'll have to look. I doubt I have anything esle you will need.
Author:  Philip's66 [ Sun Feb 03, 2013 11:28 am ]
Post subject:  Thanks
Let me know. Gotta start somewhere,FSM will be the next item.
