It is currently Thu Jul 02, 2026 8:12 pm
PostPosted: Mon Jan 21, 2013 9:15 pm
Just removed my exhaust manifold from my '63 225 I'm rebuilding. It was difficult to remove, due to some rusty manifold-to-tailpipe flange bolts. But finally got them off today.
The manifold is the earlier style with the semi-closed choke pocket. I cannot tell if it's original to the car, but see the numbers on it, maybe some of you can identify and let me know. I do notice the CDPD on it: perhaps this is original equipment? I remember reading somewhere here that manifold engineering and manufacturing progressively added 'ribs' to the manifolds to prevent cracking, but I don't remember what was specific for 1963.
The manifold has no visible cracks, and worked fine before I removed it. The heat riser flap is frozen and the counterweight had been held in place for years and years with a jury-rigged wire; I assume in the open position (though it doesn't look 'opened' to me). Aside from the frozen riser, the only other issue to deal with is one of the long intake manifold screws broke off when I was trying to remove it. You can see the broken screw where the manifold V's together.
Is the manifold worth the trouble to take it to a machinist and have them machine out the broken screw? I haven't seen reproduced manifolds that have the earlier-style semi-closed choke pocket. How necessary is this for proper choke functioning? AND, if I manage to solvent-up the heat riser flap and get it moving correctly, the thermostatic heat spring seems loose: is this something to replace?
Let me know your thoughts guys, thanks.
PostPosted: Mon Jan 21, 2013 10:52 pm
6 Pack Dart
Put PB blaster on the shaft where it goes into the manifold, then with a small hammer gently tap the shaft on the ends back and forth. After repeating this process a couple of times the shaft will break loose.
Richard
PostPosted: Tue Jan 22, 2013 6:12 am
+1 on the PB blaster, it will come free eventually. If crack-free, it would be worth fixing to me even if I had to pay to for the bolt repair, that would probably cost the same or less than a junkyard part that is likely to have same or worse issues. I'm lucky to have a friend that has mad skills when it comes to broken bolt removal/repair, but I would guess that my machinist would probably charge $25 for that one bolt repair and he'd probably get the flap un-stuck at the same time.
FYI: The riser flap appears to be stuck in the 'closed' position diverting exhaust down/away form intake.
1966 Coronet Deluxe
PostPosted: Sun Feb 03, 2013 10:05 pm
Thanks, I'll take the manifold in to a machinist. I would rather try and use the original than have to order a new one, if possible.
Users browsing this forum: Amazon [Bot] and 6 guests
