It is currently Wed Jun 17, 2026 5:12 am
 Post subject: Denso 211-0121
PostPosted: Mon Feb 18, 2013 1:37 pm
I'm upgrading my charging system on my 62 Valiant with the goal of more consistent voltage output. I want to avoid a re manufactured alternator and can't find the earlier Denso new. I realize that I don't need all the amps and will switch to a voltage gauge.
Is the Denso 211-0121 my best choice? Is it difficult to convert to a v pulley?
I am currently running a stock alternator with electronic regulator and HEI. Also have electric fuel pump and may add electric fan, but I think I could still get by with less amps.
Why? I had some problems with my EFI CPU and the tech support told me to reload the software and low and or inconstant voltage corrupts files.
Cheers,
Barnaby
These ones go to eleven...
PostPosted: Tue Feb 19, 2013 7:30 pm
I would do some checking around local junkyards and see if you can find a used one that can be rebuilt locally.
Love inline sixes
78 AMC Concord 258
PostPosted: Wed Feb 20, 2013 7:17 pm
I got one at the Pick A Part in Tacoma from a 92 Dakota with a standard pulley. You can buy a pulley and swap it out......Our Auto Parts store in Black Diamond has all the pulleys hanging on the wall. The local "Rebuilder" in Kent has them too...
The Pick A Part said 89 to 92's had standard pulleys.
 Post subject: 90 max...
PostPosted: Wed Feb 20, 2013 7:54 pm
I think I'd go 1990 max...my 1992 Ramcharger 5.2 was serpentine belt...my uncle's 5.2L Dakota is also serpentine belt...
Maybe I should check my local pick-a-part just down the raod from the shop since they are pre-92.
