It is currently Fri Jun 05, 2026 10:05 pm
PostPosted: Fri Feb 08, 2013 6:48 pm
I am helping a local shop with a 66 Barracuda and they need pictures of a power steering pump mounted on a slant six engine. Any help is appreciated!
 Post subject: What?
PostPosted: Fri Feb 08, 2013 8:02 pm
U bracket mounts to the drivers side of the block to the 2 or 3 bolt holes just in front of the driver's side motor mount above the oilpan rail...
After that you insert the pump body partially until you can get the top bolt into place then partially install the lower bolt, install belt and adjust tension....
PostPosted: Sat Feb 09, 2013 8:41 am
thanks dusteridiot. have any pictures? i don't have any ps parts or brackets here to help them. they have had a ladies 66 for 2 years and i want them to get it done and back to her.
PostPosted: Sat Feb 09, 2013 9:45 am
Google Image Search: slant six power steering pump
1964 Dart GT
PostPosted: Sat Feb 09, 2013 12:10 pm
Thanks Man!
