Super Six Kickdown Linkage
https://slantsix.org/forum/viewtopic.php?t=51072
Author:  jhdeval [ Sun Feb 10, 2013 9:19 pm ]
Post subject:  Super Six Kickdown Linkage
Okay so I have now bought my Super Six and a Carter BBD. I still need to do the kickdown linkage and gas pedal.
If anyone has a gas pedal kicking around to finish the conversion I would be willing to discuss it.
I found on eBay a Kickdown Linkage. How does this look?
http://www.ebay.com/itm/GEARHEAD-CHRYSL ... 42&vxp=mtr
Author:  DusterIdiot [ Sun Feb 10, 2013 9:35 pm ]
Post subject:  Looks about right...
Looks similar to the Lokar Cable system (if exactly as pictured) but at a lower cost.
If you can't find a 1966 A-body gas pedal and a 1974 V-8 throttle cable (best match for the application). I have the throttle cable, but only have post 1967 pedals which can be made to work...
Author:  Super6er [ Thu Feb 14, 2013 6:02 pm ]
I have a gas pedal cable I pulled at a junk yard, it 21" in total length.
Not sure if it will work for your application cause i never tried to install it, but if you want it you can have it for what I paid... 6 bucks.
plus shipping to you.
Author:  DusterIdiot [ Thu Feb 14, 2013 9:21 pm ]
Post subject:  Done...
I already sent him a pedal and supersix throttle cable (they are shorter than the stock 1 barrel cable...21" would work great for a hyperpak or Aussiespeed though).
:wink:
Author:  jhdeval [ Fri Feb 15, 2013 10:01 pm ]
DusterIdiot I received the pedal and throttle linkage today thank you. It looks like it will work well.
The last thing I need or need to figure out is the transmission kickdown linkage. Charlie had suggested going to a local bike shop and I am good with that but he did not give enough info for me to figure it out.
Based on the pics I have found it looks like the throttle cable attaches to the top of a moon shaped bracket while the transmission linkage attached on the bottom with springs pulls. The problem is I have not seen a single image of the transmission side. Does it connect all the way down under the car or does it connect to the existing linkage?
Author:  jhdeval [ Sat Feb 16, 2013 6:07 pm ]
Anyone?
Author:  DusterIdiot [ Sat Feb 16, 2013 7:26 pm ]
Post subject:  It...
The Lokar setup has a bracket that is bolted under one of the rear bolts on the tailshaft to body assembly on the tranny. The end of the cable has a bolt that bolts through the stock kickdown actuation arm on the tranny.
Author:  Fopar [ Sat Feb 16, 2013 8:55 pm ]
See in this post, if you scroll down you will see pictures of cable hookup.
http://slantsix.org/forum/viewtopic.php ... e+kickdown
Richard
