| Pilot bushing https://slantsix.org/forum/viewtopic.php?t=51099 |
| Author: | Mr.Sixpack [ Wed Feb 13, 2013 12:11 pm ] |
| Post subject: | Pilot bushing |
Is the /6 pilot bushing in the crank the same as sb? I need to change mine before I put the 3 speed in the car. I saw a roller pilot bushing on Mancini Racing for smallblock, will it fit my /6. Thanks. |
| Author: | Joshie225 [ Wed Feb 13, 2013 12:16 pm ] |
The roller pilot bearings only fit large counterbore cranks as they fit the torque conveter pocket. The bushings are the same though. |
| Author: | DusterIdiot [ Wed Feb 13, 2013 12:26 pm ] |
| Post subject: | As Josh Said... |
Per Joshua this will only cranks manufactured for the 1968 model and later. -D.Idiot |
| Author: | Mr.Sixpack [ Wed Feb 13, 2013 12:32 pm ] |
My charger is a 68 and the engine is matching number. But I'll have to measure the crank and see how big it is. Thanks |
| Author: | DusterIdiot [ Wed Feb 13, 2013 12:38 pm ] |
| Post subject: | Yep... |
Quote: But I'll have to measure the crank and see how big it is.
Just the pocket diameter....1.805 ID or so should be correct.-D.idiot |
| Author: | Mr.Sixpack [ Thu Feb 14, 2013 7:16 am ] |
Thanks you -D.idiot |
| Author: | hantayo13 [ Thu Feb 14, 2013 12:20 pm ] |
don't forget to fill bushing before install.....set on thumb,fill with oil,press with finger till oil flows out side of bushing....koolest thing I ever seen ...now you h |
