wide ratio 904
https://slantsix.org/forum/viewtopic.php?t=51106
Author:  oldnslo [ Thu Feb 14, 2013 4:50 pm ]
Post subject:  wide ratio 904
Are all the wide ratio 904's lockup transmissions?
Author:  slantzilla [ Thu Feb 14, 2013 10:42 pm ]
I believe so, but you can put the gear sets in a non lockup.
Author:  Fopar [ Thu Feb 14, 2013 11:40 pm ]
I got one from a V8 (think it was a small block) no lockup. You just need the sun gear and the planitaries you can also use the bigger clutch pack.
Richard
Author:  Reed [ Fri Feb 15, 2013 12:07 am ]
The above answers are both right. All post 1980 904s, 6 and 8, are wide ratio. Heavy duty post 1980 v-8 applications could be had with a non-lockup transmission, as could certain 6 cylinder applications. For example, I once owned a 1986 Dodge B-150 van built for the California market and it had a factory non-lockup 904. As has been stated above, the gearsets and clutch packs will swap right into an earlier non-lockup slant six case. Or the lockup function can very easily be disabled.
