| camshaft gear? https://slantsix.org/forum/viewtopic.php?t=51111 |
| Author: | slant6 [ Thu Feb 14, 2013 8:13 pm ] |
| Post subject: | camshaft gear? |
The bolt that holds on the cam gear, what is it torqued at, tia |
| Author: | DusterIdiot [ Thu Feb 14, 2013 9:17 pm ] |
| Post subject: | It's... |
50 ft/lbs...for cam bolt. If you feel you aren't going to make any more changes to the timing and will be doing some high rpm time threadlock the bolt before torquing it. -D.Idiot |
| Author: | slant6 [ Fri Feb 15, 2013 4:47 pm ] |
| Post subject: | cam sprocket bolt |
Thanks for quick response, I will be asking more que. Stay tuned, Dana |
