It is currently Tue May 12, 2026 2:19 am
 Post subject: camshaft gear?
PostPosted: Thu Feb 14, 2013 8:13 pm
The bolt that holds on the cam gear, what is it torqued at, tia
 Post subject: It's...
PostPosted: Thu Feb 14, 2013 9:17 pm
50 ft/lbs...for cam bolt.
If you feel you aren't going to make any more changes to the timing and will be doing some high rpm time threadlock the bolt before torquing it.
 Post subject: cam sprocket bolt
PostPosted: Fri Feb 15, 2013 4:47 pm
Thanks for quick response, I will be asking more que. Stay tuned, Dana
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
