| Engine ID! https://slantsix.org/forum/viewtopic.php?t=51136 |
| Author: | Mrroth71 [ Sun Feb 17, 2013 6:26 am ] |
| Post subject: | Engine ID! |
HI! The engine in my -64 valiant has been replaced, it´s still a 225" but i would like to know more. On top of the block ( over nr 1 sparkplugg)it´s says: I 225 R 1203 E Under the intake manifold ( in the casting) it´s says: 330-3 6 16 81 IF I live in Sweden and english is not really my language so i apologize for any misspellings Best regards Mrroth71 |
| Author: | Mrroth71 [ Tue Feb 19, 2013 12:20 am ] |
correction: On top of the block ( nr 1 sparkplugg)it´s says: 1 225 R 1203 E The block is light blue/ almost grey The head is blue and the valve cover black . I don´t know if the colour is a hint of the production year. Best regards Mrroth71 |
| Author: | Doc [ Tue Feb 19, 2013 10:53 am ] |
Sounds like a later cast crank engine. (5 core plugs in the side) See this article for more info: http://www.slantsix.org/articles/dutra- ... blocks.htm DD |
| Author: | Mrroth71 [ Sat Feb 23, 2013 8:41 am ] |
Hi! Yes, you are right, i have 5 core plugs. but i still don´t know the year of the engine. My guess is that the numbers 6 16 81 in the casting under the intake manifold means 16 june 1981, but it´s only a guess. // Mrroth |
| Author: | Mrroth71 [ Mon Feb 25, 2013 12:53 pm ] |
| Post subject: | More info!!! |
More info on my engine: 5 core plugs No spark plug tubes. Hydralulic lifters!! On top of the block ( nr 1 sparkplugg)it´s says: 1 (one) 225 R 1203 E // Mrroth |
| Author: | cpslntdchrg [ Mon Feb 25, 2013 1:43 pm ] |
First reference http://www.hotrodreference.com/8/chrysl ... g-numbers/ http://www.forabodiesonly.com/mopar/sho ... p?t=186070 Of course, yours is not there... I found a thread with something similar... http://www.slantsix.org/forum/viewtopic ... 471d7d3516 last generation with the forged crank? |
