| Turbo cam? https://slantsix.org/forum/viewtopic.php?t=51151 |
| Author: | RyGuyTooDry [ Mon Feb 18, 2013 3:14 pm ] |
| Post subject: | Turbo cam? |
I'm in the midst of building a mild turbo slant (turbo manifold, t25, 10 psi, bigger valves and a port/polish). I was just curious as to what kind of cam I should use. Comp cams has a .435 flat tappet, which I was considering using, but does anyone have any other suggestions? |
| Author: | Fopar [ Mon Feb 18, 2013 5:04 pm ] |
Unless you want to turn more than 5K use the stock cam. Richard |
| Author: | Valleyant [ Mon Feb 18, 2013 5:21 pm ] |
I am using the stock cam on my '70 Slant 6 Turbo build. You could take advantage of Chryslers research and look at the profile of the turbo 2.2 and 2.5 four cylinder engines of the '80's and '90's if you are having a custom grind made. |
| Author: | Shaker223 [ Mon Feb 18, 2013 5:31 pm ] |
With enough boost and tuning a stock cam can put a 70 A body into the 11's. |
