steel shim head gasket
https://slantsix.org/forum/viewtopic.php?t=51155
Author:  Junior [ Tue Feb 19, 2013 2:21 am ]
Post subject:  steel shim head gasket
what is the likely hood that a new steel shim head gasket will work without machining the head or the block?
Author:  emsvitil [ Tue Feb 19, 2013 2:28 am ]
Off the top of my head I'm going to say....
zero
Author:  Charrlie_S [ Tue Feb 19, 2013 3:27 am ]
Check the deck, and the head with a straight edge. My cuda has a shim gasket without cutting the deck, but does have a milled head.
My 66 Valiant was originally built with the shim gasket and no cut on the head or block. Ran a couple of seasons, before we cut the head, for a compression increase. Still using the shim gasket.
Author:  Doc [ Tue Feb 19, 2013 11:06 am ]
Could work... IF you have a "long board" sanding block and a lot of "elbow grease".
You will have to pull the dowel pins out of the block deck and start sanding... and checking, with a straight edge, before you know for sure... If the head or block is un-even or warped, it is best to spend the $$ to get them resurfaced.
It is always interesting to see the "high - low" areas when you start sanding... the block in my photos below had "zebra stripes". :shock: :?
Author:  Junior [ Tue Feb 19, 2013 1:41 pm ]
thanks for the replys guys.
doc, is that "board" wood or a piece of steel?
Author:  Aggressive Ted [ Tue Feb 19, 2013 1:48 pm ]
I use 16 ply Finish Birch plywood. It works very well.
Author:  Junior [ Tue Feb 19, 2013 3:23 pm ]
what grit sand paper?
also my block isnt disassembled is there a way to keep the metal shavings out of the passages?
Author:  hantayo13 [ Wed Feb 20, 2013 5:24 am ]
also my block isnt disassembled is there a way to keep the metal shavings out of the passages? NO
Author:  Aggressive Ted [ Wed Feb 20, 2013 7:36 pm ]
80 grit belt from a vertical belt sander belt. Use a little WD 40.
Author:  Junior [ Thu Feb 21, 2013 12:23 am ]
cool, thanks man
