| speedo cable https://slantsix.org/forum/viewtopic.php?t=51171 |
| Author: | valiant effort [ Wed Feb 20, 2013 3:59 pm ] |
| Post subject: | speedo cable |
can anyone tell me the correct part number for the speedometer cable for a 1964 valiant automatic. I ordered 1 from Rock auto and of course it is not the correct 1 . the 1 I need screws on at the speedometer but pushes in at the transmission . Just replacing the inner cable will not work as mine is totally mangled thanks |
| Author: | 64ragtop [ Wed Feb 20, 2013 7:13 pm ] |
'64 parts manual shows the cable as part #21-84-1. I found one N.O.S. on ebay, HERE. Or, Schumacher Creative Services has new ones here, scroll down about 2/3rds of the page. ATB BC |
| Author: | valiant effort [ Thu Feb 21, 2013 6:06 am ] |
| Post subject: | apwwdp |
Thank you very much |
| Author: | 64ragtop [ Thu Feb 21, 2013 1:03 pm ] |
Glad I could help! ATB BC |
| Author: | Danarchy [ Thu Feb 21, 2013 1:25 pm ] |
http://www.imperialservices.net/Aparts.html Imperial has them also. |
| Author: | valiant effort [ Tue Feb 26, 2013 6:04 am ] |
| Post subject: | Speedo |
I would guess they instruct you on what kind of lubricant to use but if not, what did you guys use..thanks |
| Author: | 64ragtop [ Fri Mar 01, 2013 8:44 pm ] |
Use a good quality silicone grease all up and down the inner cable, and then wipe it off the top 6 inches or so. That grease can migrate into your speedo and kill it. ATB BC |
| Author: | valiant effort [ Fri Mar 01, 2013 9:45 pm ] |
| Post subject: | cable |
Thanks again! |
| Author: | 64ragtop [ Sat Mar 02, 2013 4:44 pm ] |
With that done, your speedo cable should serve well for another 40 - 50 years. I don't know about you, but in four decades I'm pretty sure I'll be pushin' up daises and won't care if the speedo works ATB BC |
| Author: | valiant effort [ Sat Mar 02, 2013 5:02 pm ] |
| Post subject: | speedo |
Considering Im over ten years older than the car I would concur |
