| New Member with a few issues https://slantsix.org/forum/viewtopic.php?t=51172 |
| Author: | Eggman63 [ Wed Feb 20, 2013 4:44 pm ] |
| Post subject: | New Member with a few issues |
Hello Slanters!I recently bought a 87 D-150 shortbed with of course a Slant6.It runs fairly well but has a,for the lack of a better word,skip while driving at 50 or any other steady speed.I did some adjusting and have a question about timing.The ESA is still in the fender and is hooked to full manifold vac.When I put a timing light on it I can set it at 16 degrees base as per the hood sticker but if I rev it I get no advance.Does it only advance under load or is the computer not operating? |
| Author: | Ed Mullen [ Wed Feb 20, 2013 6:36 pm ] |
Sounds like the ESA has had it and it's time to consider alternate ignition systems. (HEI is easiest option for a lean burn vehicle, and probably also the best.) ESA, if working, advances timing with vacuum applied--period. |
