Differential Fluid
https://slantsix.org/forum/viewtopic.php?t=51190
Page 1 of 1
Author:  SpaceFrank [ Fri Feb 22, 2013 12:15 pm ]
Post subject:  Differential Fluid
Possibly a dumb question, but all my search-fu yielded no relevant results. What is the recommended fluid to put in a 7.25" rear end? I will be "road racing," if it matters. You can basically read that as "I will be driving to work really hard through the city for hours at a time."
Also, recommendations for housing cover gaskets? Anything special out there? Mine shows signs of leaking.
I don't know my gear ratio, but it's likely high 2s-low 3s.
Author:  DusterIdiot [ Fri Feb 22, 2013 1:05 pm ]
Post subject:  What rear axle?
Depends on the axle type for gaskets (only a couple brands offered at all for the 7 1/4"), 8 1/4" and 8 3/4" are very available.
If you have a performance differential, follow the instructions on lube for the diff type (trac lock, ARB, etc...). I haven't had any problems using an over the counter gear oil with a stock mopar rear even with stock sure-grip.
Author:  Supercharged SL6 [ Fri Feb 22, 2013 5:31 pm ]
RTV silicone gasket maker would be fine for a rear axle cover, if you can't find a gasket readily, 80-90 gear oil should be fine, 85-120 would be better in hot weather, if it's a posi make sure oil is compateable with a limited slip axle, most brands will say on the bottle
