Turn Signals flash all lights
https://slantsix.org/forum/viewtopic.php?t=51203
Author:  ILMopars [ Sat Feb 23, 2013 5:45 pm ]
Post subject:  Turn Signals flash all lights
Here is one of many problems with my Dart Leela. Everytime I go to make a turn, and I put on the turn signals the lights flash correctly but when the lights are on their brightest point the other lights dim, every light on the car dims when the turn signals get brighter. Voltage regulator? GFS on the wiring?
Author:  ILMopars [ Sun Feb 24, 2013 10:15 am ]
Bump
Author:  Fopar [ Sun Feb 24, 2013 10:51 am ]
Might be just bad contacts (corosion on contact points in wiring). :roll: :idea:
Richard
Author:  DusterIdiot [ Sun Feb 24, 2013 5:15 pm ]
Post subject:  On later cars...
This can happen if you have a ground connection that is not 100% connected....look at the engine bay harness ground connections
especially. I also would start to suspect the steering column wiring/ connections. How old is your voltage regulator?
Author:  ILMopars [ Sun Feb 24, 2013 5:40 pm ]
Voltage regulator is the one the factory put on. Has the tell tale dimple on the cover.
