| 7.25 rear end gear change to 3.55 https://slantsix.org/forum/viewtopic.php?t=51250 |
Page 1 of 3 |
| Author: | Super6er [ Wed Feb 27, 2013 2:52 pm ] |
| Post subject: | 7.25 rear end gear change to 3.55 |
I picked up a good deal on a new 3.55 motive gear set from Jegs through their price match guarantee it took about 3 weeks but finally got here. this will be my first attempt at a gear change so if you have any pointers or useful information I would really appreciate it. pictures would be great....I read the directions and it seems the hardest thing will be setting the tolerances. |
| Author: | Junior [ Wed Feb 27, 2013 3:44 pm ] |
http://www.jeepforum.com/forum/f11/gear ... -a-109859/ its for an 8.25 but its pretty much the same for the 7 1/4. |
| Author: | Super6er [ Wed Feb 27, 2013 3:51 pm ] |
Thanks for the quick reply, draining the oil now so ill get to ready it. |
| Author: | 64DartGT [ Wed Feb 27, 2013 4:31 pm ] |
Can you post the part number from Jegs of the set you ordered I am going to rebuild my 7.25 sometime and am thinking of going with a different gear........Thanks |
| Author: | Super6er [ Wed Feb 27, 2013 5:57 pm ] |
Here's a pic with part number for the gear. It will show up around $269 but I used there price match and got it for $189 took three weeks to get here though not a stocked part. I will look for the link I sent them for the discount, and post it on here for you. https://www.dropbox.com/s/e49m2ijwtsmym ... .45.28.jpg |
| Author: | 64DartGT [ Wed Feb 27, 2013 6:02 pm ] |
Thanks sounds like you got a good deal........... |
| Author: | Super6er [ Wed Feb 27, 2013 6:11 pm ] |
I'm stuck at this point, not sure how to slide the axels out?. I don't see any other clips. What am I missing? https://www.dropbox.com/s/tcvvis9yjn5a7 ... .23.03.jpg |
| Author: | 64DartGT [ Wed Feb 27, 2013 6:18 pm ] |
Did you remove the bolts at the brakes that holds the axles in? |
| Author: | Super6er [ Wed Feb 27, 2013 6:45 pm ] |
No....but got them out now. Thx. |
| Author: | Supercharged SL6 [ Wed Feb 27, 2013 6:46 pm ] |
I beleive you need to pull the pin that holds the spider gears in the case, pin is held in with 5/16 head bolt. After pin is out push axles into case C clips should fall out, then pull axles out |
| Author: | DusterIdiot [ Wed Feb 27, 2013 6:55 pm ] |
| Post subject: | Lol... |
Quote: I beleve you need to pull the pin that holds the spider gears in the case, pin is held in with 5/16 head bolt. After pin is out push axles into case C clips should fall out, then pull axles out
That's only on the 8 1/4" and 9 1/4" mopar rear axle, they are doing a 7 1/4" which is actually more like the 8 3/4" for axle retainage but does not have the drop out 3rd member...(in this case they have to remove the retainer at the axle ends to remove the axle). -D.Idiot |
| Author: | 64DartGT [ Wed Feb 27, 2013 7:11 pm ] |
Post plenty of pics if you can so I can look back at them when I do mine...... |
| Author: | Supercharged SL6 [ Wed Feb 27, 2013 7:11 pm ] |
Never rebuilt a 7 1/4 was thinking it was like a 8 1/4 |
| Author: | Super6er [ Wed Feb 27, 2013 7:19 pm ] |
Took bolts out and Axels now slide out out now but still can't get gear out?. https://www.dropbox.com/s/zvziwl7m8k5au ... .53.44.jpg I don't see any other clips. |
| Author: | Super6er [ Wed Feb 27, 2013 7:24 pm ] |
Fyi, I was able to remove the pinion bolt by placing a pry bar for back up and using a good impact. Did not need the special tool. https://www.dropbox.com/s/u6suq9s9fvjwg ... .23.18.jpg |
| Page 1 of 3 | All times are UTC-08:00 |
