It is currently Mon Oct 12, 2026 5:23 pm
 Post subject: Solid Motor Mounts?
PostPosted: Wed Feb 27, 2013 1:16 pm
Does anyone know if there is solid motor mounts for a slant sold anywhere? They are for my '65 b body
1965 Plymouth Belvedere II Turbo Project - SOLD
2002 Subaru OBS
1995 Lexus LS400 Race Car
 Post subject: No but...
PostPosted: Wed Feb 27, 2013 3:54 pm
There are poly mounts that are pretty stiff, and if really wanting solid mounts you can always pull your old ones out and have a buddy burn the rubber out with a torch and weld a chunk of box iron in place of the rubber( or bolt through some plates as proper spacers...)
PostPosted: Thu Feb 28, 2013 8:50 pm
I'm cheap. I like free stuff. I like the DIY ideas above.
I welded some scraps across a failed mount on one of my other toilets (non slant) and it held up for a very looong time, in fact, they held all the way up to the moment the slicks were bolted up. Until then, that mount was just plain ugly. After then, it was real ugly.
1966 Coronet Deluxe
PostPosted: Thu Feb 28, 2013 11:14 pm
I made a pair for my '66 Valiant from some 2x2 box tube and some 1/2" bolts. Get used to tightening loose bolts.
Users browsing this forum: Bing [Bot] and 18 guests
