crankshaft Question?
https://slantsix.org/forum/viewtopic.php?t=51272
Page 1 of 1
Author:  slant6 [ Fri Mar 01, 2013 12:24 pm ]
Post subject:  crankshaft Question?
What does a crankshaft oil slinger look like? Also does my 6 cyl suppose to have one? And if so does it get installed between block and timing gear, Thanks again, Dana
Author:  Fopar [ Fri Mar 01, 2013 4:05 pm ]
Some have others don't, it will go on after the crank sprocket.
It looks like a large thin washer with a keyway slot in the inner hole.
Richard
Author:  slant6 [ Fri Mar 01, 2013 4:12 pm ]
Thanks Richard
Author:  DusterIdiot [ Sun Mar 03, 2013 3:46 pm ]
Post subject:  Yep...
I have found that the 60's slant sixes have mostly had these as a stock item, about the eraly 70's they seem to hit and miss, but mostly miss..
