can someone please help??
https://slantsix.org/forum/viewtopic.php?t=51283
Author:  86ramslant6 [ Sat Mar 02, 2013 2:44 pm ]
Post subject:  can someone please help??
I am trying to finish the intake and exhaust manifold on my truck and I can't remember how the linkages go on the carb. also I can't seem to remember where the springs go. PLEASE HELP! I need to get the truck back on the road. Thanks
Author:  64ragtop [ Sat Mar 02, 2013 3:46 pm ]
It would be a big help if we knew what year and make /model carb you're installing. Linkages, springs and vacuum hoses change with those factors. Help us help you.
ATB
BC
Author:  86ramslant6 [ Sat Mar 02, 2013 4:15 pm ]
thought about that after i went back outside. My truck is an 86 and i have a holley 1945 carb. I have the vacuum lines figured out just need the linkages and springs thank you
Author:  Aggressive Ted [ Sat Mar 02, 2013 4:18 pm ]
You can look at my photos......just click on the red link below my name.
My car came with a 1945 but replaced it with a 1920 Economaster. It shows the cable linkage and springs..... :)
Author:  86ramslant6 [ Sun Mar 03, 2013 2:38 pm ]
thanks! your pictures help me a little but it may be better if someone that has the same setup as me could help. I have 3 springs and am only seeing 2 on your setup.
Author:  Reed [ Sun Mar 03, 2013 5:51 pm ]
Two springs are the throttle return springs, one spring is the kickdown linkage tensioning spring. The two springs have a large coil and a small coil. The small coil nests inside the large coil. This "spring pack" runs between the throttle arm on the carb and a little bracket that bolts to the choke thermostat pocket on the exhaust manifold. The third spring hooks to the kickdown arm and to the throttle arm on the carb.
