It is currently Wed Nov 18, 2026 12:16 am
PostPosted: Fri Apr 26, 2013 4:37 pm
Has anyone installed part throttle kickdown on an early 904? Is it possible? If yes I want to do it.
I am running the Lokar cable, transgo, 2200 stall, internal filter and Hayden cooler. Work beautifully except the kickdown. I works but boy do I have to step on it...
Cheers,
BT
These ones go to eleven...
PostPosted: Fri Apr 26, 2013 5:24 pm
I believe Pat Blais (Torqueflite Patty) has a kit he sells on eBay to retrofit part throttle kickdown to the early 904 valve bodies. I don't even think it is that expensive.
Yeah, see the desciption in THIS eBay auction. I have purchased from him several times and he is a top notch supplier and good guy.
PostPosted: Fri Apr 26, 2013 5:57 pm
Thanks Reed!
It looks like his shop is in Seattle, heck I might just drive the Valiant up and have him do the install, maybe a deep pan too?
Awesome!
Barnaby
PostPosted: Fri Apr 26, 2013 6:42 pm
I don't know if he actually installs parts, or even has a brick and mortar store. He stuff is first rate though, and he has forgotten more about the torqueflite than I will ever know.
PostPosted: Fri Apr 26, 2013 10:57 pm
Again great lead. I'll call on Monday, fingers crossed that it is brick and mortar and hands on...
BT
PostPosted: Tue Apr 30, 2013 4:24 pm
Just got off the phone with Pat Blias. This guy is a wealth of 904 knowledge, and he is setting my 904 with part throttle kickdown. He can do bench work, but not a full shop. Fair pricing too.
Suggested installing a tranny temp gauge on the line to the cooler. Has anyone done this? Real curious to see my temp especially with the stall converter.
Cheers,
Barnaby
