It is currently Mon Oct 12, 2026 9:31 am
 Post subject: cam sprocket stop?
PostPosted: Sat Mar 02, 2013 10:54 am
I have 69 motor, 225, if sprocket gear and crankshaft gear line up great do I or should I add a sprocket stop? Advise, thanks again Dana
PostPosted: Sat Mar 02, 2013 9:16 pm
Site Admin
Are you asking about a cam button? Something to keep the cam from moving forward, or is it something else?
A cam button can be a good idea if the engine will see high rpm. If you do a search, you will find some great info here for making an inexpensive cam button. I've got years of racing seeing 5000 rpm regularly, and haven't had a problem. Folks that tach them up to 6000 or higher regularly put them on to keep the cam where it belongs. It can also be useful for off road vehicles that are used in extreme conditions.
For a daily driver that won't see high rpm, you can install one, but it isn't generally necessary.
CJ
PostPosted: Sun Mar 03, 2013 5:09 am
CJ,
Just what is a cam button; where is its placement, and would you have a photo of one?
Bill
PostPosted: Sun Mar 03, 2013 7:53 am
Site Admin
Here's one type.
http://www.jegs.com/i/Crane-Cams/271/99 ... Id=1575362
Doc has some info about making one from an old rocker adjuster. A quick search will find it.
CJ
PostPosted: Sun Mar 03, 2013 2:23 pm
CJ,
Found it, thanks.
My car has not had this modification.
Bill
 Post subject: I would...
PostPosted: Sun Mar 03, 2013 3:28 pm
This is just cheap insurance on the daily driver if the timing chain stretches a bit and the cam walk forward and causes a problem with
the oil pump gear (especially if it's not an OEM pump/gear)...The price and time to do it outweighs the 'what if' factor on the daily driver that might see lots of miles.
Users browsing this forum: Google [Bot] and 15 guests
