Ammeter dropped to D side?
https://slantsix.org/forum/viewtopic.php?t=51321
Page 1 of 1
Author:  64DartGT [ Tue Mar 05, 2013 11:53 pm ]
Post subject:  Ammeter dropped to D side?
While letting my car warm up last night, no lights on the ammeter dropped to D side and car shutdown. Starter spins over but motor will not crank? Is my voltage regulator bad? I recently put a new alternator on to replace my old one the bearing was failing on its a sixty amp one from Rock auto........
Author:  Supercharged SL6 [ Wed Mar 06, 2013 6:15 pm ]
If the starter motor is running and not cranking the motor over, I would say the starter is bad, if the motor is cranking over and will not start check for spark from coil if no spark you probably have a electrical problem what kind of car- truck you got
Author:  64DartGT [ Wed Mar 06, 2013 6:43 pm ]
Its a 1964 Dodge Dart 225 slant three speed manual transmission. Got it started but it has a slight spit to it and the ammeter jumps a little .....thanks for the reply...
